Back-up lights don't come onVegasli 11-24-2006, 11:57 AM I own a 2003 Chevrolet Trailblazer EXT. When I put my car on reverse back-up lights do not come on. I checked the fuse box in the engine compartment & changed the light bulbs, but the problem still exist. What else can I do to fix this problem? Thank you & have a nice day:p maxwedge 11-24-2006, 05:39 PM These issues can be simple as bulbs, but if not then it can get tough, not 100% sure here, but I believe the trans range switch sends a signal to both bcm and pcm and the bcm commands the bu lites, without a real wiring diagram , tough to tell. I assume you checked for 12v and ground at the sockets. Alldata.com has complete online manuals for 25.00 for 1 year access. rodeo02 11-26-2006, 02:32 PM Didn't the 2002-2003's have issues with the lamp holders/sockets for the rear lense assemblies? Hopefully it's just that. A quick check for a functioning trans range/mode sensor is watch the PRND321 dash lights. If they flicker, flip around at random or dont line-up with what you selected with the floor shifter, you've got a range sensor issue. I believe it's internal to the trans on the 4L60E. A bad range sensor will make the trans shift in failsafe mode which will give harsh shifts. Joel edbrycem 11-27-2006, 11:29 PM I think that light issue was primairly for the brake lights not working.......I could be wrong though. maxwedge 11-28-2006, 04:27 PM Correct, but it is possible the bu lites could be affected hence the prior suggestion to confirm 12v and gd at the sockets. Automotive Network, Inc., Copyright ©2012
