fan not working in 99 s10kingman200154 11-23-2006, 10:05 PM i just bought a 99 s10 4.3 vortec and i cant get any kind of air to blow out the vent can anyone tell me what i should check before i have to take it to a shop? wirenut699 11-23-2006, 10:29 PM Is it that the fan will not run on any speed? or the fan is running but air is not making it out of the vent slots? kingman200154 11-24-2006, 08:52 PM not sure i turn the fan on and there is no noise or anything, is there a way to see the fan? rhandwor 11-24-2006, 09:27 PM You can reach your hand up behind the heater core and feel the fan. Un plug the fan and check for voltage. The fan motors aren't to expensive at the parts store. kingman200154 11-24-2006, 09:30 PM my sound silly but im just learning to work on trucks , how would i check if there is voltage? BlazerLT 11-24-2006, 10:43 PM I suggest getting a repair manual. It will show you how to reach the fan. Will the fan run on maximum? rhandwor 11-25-2006, 08:35 AM If you can't afford a repair manual go to the library and then copy the page. Use a volt meter or 12volt test light. One is placed on a ground and the other end in the electrical conn. Turn the fan on max. if you have voltage it should run. Their resisters for for various fan speeds. Automotive Network, Inc., Copyright ©2012
