Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 11-20-2006, 01:05 PM   #1
750iL96erbill
750iL96erbill Normal reputation
Unhappy Steering wheel won't retract
Hello,
As you can see, I am a newbie, and I just got my 96 750, and I am having, what I believe might be a relay problem.
When I turn the car off, the steering wheel does not move up and away. I can move it with the control, but only when the drivers door is closed. The memory controls work, but only if you hold the button, and it does not matter if the door is open or closed. I read, if the door is closed, you have to hold the button, i.e. 1,2 or 3. but if the door is open, you just touch the button, well that does not work, I still have to hold the button. This is why I am thinking a relay. I know the dealer can program some of the stuff using the key fob, but my son has a same year 740il and all that works like it should..help me please! What relay should I change and can I swap with another to try it?
I really like this car
Thank you!!
750iL96erbill is offline   Reply With Quote
Old 11-20-2006, 10:44 PM   #2
91HO305TPI
91HO305TPI Normal reputation
Re: Steering wheel won't retract
sounds more like an igniton switch issue not sending the signal that the key is off to move the steering wheel this is control buy the general modual.
somthing your not likly going to fix on your own sorry.
91HO305TPI is offline   Reply With Quote
Old 11-21-2006, 10:30 AM   #3
750iL96erbill
Thank you for replying.
I read somewhere, that it may just be a relay, or since the seat control has been repaired, it may be the master plug is loose? I have not checked any of this, but I also heard that auto away is dealer programmable. The other thing I heard is the memory control might be bad, but it works and stores everything. Do you know where a guy can find a list of relays?
Bookmarks
Google
Web AF
