Battery dischargingAurora_Alpine 11-19-2006, 06:01 PM If i don't turn my car on everyday my battery will die i don't know why but i think there's a short circuit, because there are some sound system wires loose in the trunk ( the car came like that) anyway i think that's whats causing the battery die but i took out the fuse that was powering those wires so now i don't know whats the problem. MT-2500 11-19-2006, 07:12 PM If i don't turn my car on everyday my battery will die i don't know why but i think there's a short circuit, because there are some sound system wires loose in the trunk ( the car came like that) anyway i think that's whats causing the battery die but i took out the fuse that was powering those wires so now i don't know whats the problem. Could be one of several problems. First have the charging system tested and the battery load tested. Will the battery go down in a couple of days if it is disconnected? If so bad battery. If it stays up disconnected and goes down hooked up. You need to have a amp/volts draw test run on the electrical system. Automotive Network, Inc., Copyright ©2012
