Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 11-18-2006, 07:01 PM   #1
wiringguy
wiringguy Normal reputation
94 Astro No Blower
I have replaced the switch and the blower as I just don't know what the heck is wrong.The blower doesn't operate on any of the switch settings but when i take a meter I have power at the blower connection and if you shut the switch off the power goes off.If you hook up power directly from the battery the blower works.
wiringguy is offline   Reply With Quote
Old 11-19-2006, 09:58 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Re: 94 Astro No Blower
Check the connections at the blower speed resistor and at the high speed relay. Monitor the voltage with the blower connected so you have actual load in the circuit. The resistor array will frequently appear to be intact until load is applied.
Blue Bowtie is offline   Reply With Quote
Old 11-19-2006, 02:01 PM   #3
ericn1300
AF Premium User
ericn1300's Avatar
ericn1300 Normal reputation
try turning the switch on and rapping the blower motor with the butt of a screwdriver and see if it starts. if so you will have to replace the blower motor eventualy. I found mine on the internet for $18 and kept doing the rapping trick until it arrived. My 92 was easy to get to, a few 7mm bolts was all.
ericn1300 is offline   Reply With Quote
Old 11-23-2006, 01:57 PM   #4
wiringguy
Just FYI
It turned out to be two problems
One was the relay mounted on the firewall above the blower for all the low speeds and 2nd the fuse for the high speed
Bookmarks
Google
Web AF
