Engine Light for Lean Mixture
loneranger6886
11-17-2006, 11:13 PM
2000 WRX wagon with a new short ram intake and an engine light to go with it. Lean mixture on it and i know it's from the intake but i am trying to find a cheap solution for this, i don't want to try and retune the ECu but i think that if i put in a new fuel pump, walbro probably, but i'm not sure if it's the right solution.
Jay!
11-18-2006, 03:09 AM
2000 WRX?
Which type of air sensor, and did you move it?
freakray
11-18-2006, 09:27 AM
2000 WRX?
Hard to believe that unless you did a gray import or engine swap.
Right_LiRrr
11-18-2006, 11:03 AM
as said before, moving the air sensor should get rid of the CEL.
However, if want it to stop running lean, off the top of my head, will require ECU tuning. I don't see how changing the fuel pump to a higher flow one is going to do much if the ECU doesn't know how to use it?
Also, I wouldn't think the intake itself would max out the current fuel pump.....so it comes back again to ECU tuning.
LjasonL
12-06-2006, 01:03 AM
higher fuel pressure perhaps?
loneranger6886
12-11-2006, 07:02 PM
It could be from the sensor location buz its some knock off intake, but i dont have the tools to retune the ECU and the know how to increase fuel pressure. Not really a WRX guy, just helping a friend with it.
