Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 11-16-2006, 08:16 PM   #1
DOC Henry
DOC Henry Normal reputation
2000 Astro p0304 misfire codes
121 k miles ,, Code is still the same after installing Brass insert Cap and rotor, moving plug wires from cylinder to cylinder, moving spark plug to another cylinder. Is it possible that distributor drive gear is worn to cause the same misfire #4 cylinder? Vehicle does have the idle shakes, but runs fine off idle and at higher RPMs.
DOC Henry is offline   Reply With Quote
Old 11-17-2006, 02:27 PM   #2
rdptrans
rdptrans
Re: 2000 Astro p0304 misfire codes
might have popett valve sticking on #4 injector,
ASE Master Certified With L1
GM WORLDCLASS
rdptrans is offline   Reply With Quote
Old 11-17-2006, 06:26 PM   #3
DOC Henry
Is there a test procedure for the popette valve? Is it possible to run injector cleaner in the tank to clean the popette valve?
Bookmarks
Google
Web AF
