Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > BMW > 5 Series
Old 11-13-2006, 05:00 PM   #1
atv087
atv087 Normal reputation
Send a message via AIM to atv087 Send a message via Yahoo to atv087
pulling engine 1990 525i
i unplugged everything unbolted the tranny took out the convertor bolts took off the hood took out the 2 motor mounts and the engine will come out 3 or 4 inches from the transmission and not move anymore it gets stuck. any ideas?
not stuck on exhaust or anything
atv087 is offline   Reply With Quote
Old 11-20-2006, 09:06 PM   #2
ShadeTreeBill
ShadeTreeBill's Avatar
ShadeTreeBill Normal reputation
Re: pulling engine 1990 525i
Just glanced at the engine removal procedure the other day. First step was "remove tranmisssion". What a pain.... good luck!
ShadeTreeBill
1989 525i Cirrus Blue Automatic
2002 White Malibu (wife's car!)
shade tree mechanic - an amateur or otherwise marginally competent mechanic who primarily works on cars out back under a "shade tree" which serves both to provide a cool place to work, and a handy tree limb to attach the block and tackle to remove the engine.
ShadeTreeBill is offline   Reply With Quote
Old 11-20-2006, 09:08 PM   #3
atv087
got the engine out. new one is going in as soon as its like 10 degrees warmer outside so i can feel my fingers. ill let u know how it turns out
Old 11-23-2006, 07:17 PM   #4
ShadeTreeBill
Did you have to pull the tranny? Bill
ShadeTreeBill
Old 11-23-2006, 07:38 PM   #5
atv087
nope flywheel was rusted to convertor. i jumped on the hoist and the engine popped right out.
Old 01-24-2007, 11:27 PM   #6
atv087
didnt have to pull the tranny at all i got everything all reconnected now that i have a garage to work in and its all ready to go except for the front exhaust manifold its on kind of a flex piece and i cant get the flex piece to bend enough to get it back on the studs where it belongs.
Old 01-25-2007, 09:12 PM   #7
ShadeTreeBill
Yeah, what a major pain that is.... I finally removed a few of the studs so that I could get it on, then reinstalled them after the manifold was in place.
To reinstall them put two nuts on the stud and tighten them together. Use some thread lock and screw it in. Then loosen the nuts and remove one of them. Then tighten the remaining nut. You may end up with those studs not being in the head quite as far as they should be... but that was all I could come up with....
I tried everything, crowbars, wooden planks, lots of cursing, etc.
I think if you take the manifold loose from the exhaust system.... good idea to replace those gaskets anyway, it may go on much easier...
Let me know how it runs!
ShadeTreeBill
Old 01-25-2007, 09:22 PM   #8
atv087
thanks bill i ended up getting it earlier by disconnecting the manifold and putting that on and bolting it to the head and then using a crowbar to pry the manifold onto the piece with the flex part. then i used a c clamp to pull it into place and it was a hastle that had me all yesterday and today but the car will be finished tomarow since i lost the starter bolts. also by any chance do you know or have a picture of which plug goes into where on that strip that is down underneeth the throttle body since i have no idea which one goes where now since its been months since the old motor came out.
Bookmarks
Google
Web AF
