90 wet weather stalling while cold
stanbell
11-12-2006, 09:01 PM
:banghead: I have a 1990 that stalls in wet weather. I have replaced the dist cap and wires. Do I need to replace the cold start fuel injecter or are there other things I should try first?
DFBonnett
11-13-2006, 04:49 PM
Did you replace the rotor?
Mike Gerber
11-13-2006, 08:32 PM
The generation 2 Camrys, especially the 4 cylinder 3SFE engine, had a problem where the coil inside the distributor would develop hairline cracks and short istself against any metal inside the distributor. This would be most noticable in wet/damp weather. I would change the rotor like DF Bonnett sugested, since it is a cheap and easy thing to do. If that doesn't solve the problem, I would then change out the coil. An aftermarket coil will work just fine.
Mike
stanbell
11-13-2006, 10:31 PM
I have replaced the rotor and will replace the coil and get back to you to let you know how it went. thanks
