Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > MG > MG Midget
Old 11-11-2006, 04:45 AM   #1
Mok99
Mok99 Normal reputation
79 Midget won't start...help
My 79 Midget won't start. Battery good. Starter clicks but won't turn over...thoughts???
Mok99 is offline   Reply With Quote
Old 11-11-2006, 06:06 PM   #2
Flash75
AF - Advisor
Flash75 Normal reputation
Re: 79 Midget won't start...help
Check the battery cables. They should be free of corrosion and tight. Applies to the main cable to the starter solenoid and the ground cable.
Clifton
Flash75 is offline   Reply With Quote
Old 11-12-2006, 02:47 AM   #3
KimMG
AF - Advisor
KimMG Normal reputation
If the Midget is wired in a similar manner as a B, make sure the terminals on the battery cables are clean and securely connected at both ends. Check all the brown wires at the starter, making sure they are clean and secure. If all the connections are clean, secure, and have correct voltage, it is possible that the starter is locked up. Bushings in starters wear and can bind, preventing the starter motor from turning.
KimMG is offline   Reply With Quote
Bookmarks
Google
Web AF
