97 GCL 5.2 new owner
tombstoneguru
11-09-2006, 06:35 PM
I just bought this and have no idea about the four wheel drive on this thing! I've had other 4X4s but this one has 4low and 4high and N. So do I put it in N to drive on the highway? All other 4X4s I've owned have a 2wd?
The "Check Engine Light" is on and won't go off? Runs okay though?
I can't get the oil filler cap off, it just clicks and turns?
Hope someone can help!!!!
dksob81
11-10-2006, 07:53 AM
You have the QUADRA-TRAC 4WD system, it's an all-time 4WD system, just leave it in 4 HI.
extract the codes and post them here and we will let you know what they mean.
Turn the key ON, OFF, ON, OFF, ON - the check engine light will begin to flash out the codes in double digit form with a short pause between digits and a long pause between each code.
example:
| pause || - 1 pause 2 = 12
Code 12 - battery was disconnected within the last 50 ignition cycles.
||||| pause ||||| - 5 pause 5 = 55
Code 55 - end of fault codes.
Your cap is stripped, pull up on one end of the cap (in a peeling motion) to remove the top of the cap, then you can use a pair of pliers to loosen the cap. This cap is 2 peices, with a spring on the inside, so just grab it and pull up on one side, it just just pop off the threaded part.
tombstoneguru
11-10-2006, 04:10 PM
Thanks allot! I'll try getting this thing to "cough up" a code and post it as soon as I can. Since I have no owners' manual it comes in handy having folks who know this stuff! Thanks again!
