Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 11-08-2006, 11:19 AM   #1
jamesmetairie
jamesmetairie Normal reputation
int manifold torque =-??
just bought felpro intake manifold gasket set at o,reillys for 1998 lumina 3.1 can someone tell me what is the torque specs please ? i got about 3 differant answers so far at o,reillys and auto zone. a shady tree mechanic will install tomorrow. thanks and i,ll keep you guys updated how it all turns out.
jamesmetairie is offline   Reply With Quote
Old 11-08-2006, 01:51 PM   #2
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: int manifold torque =-??
the torque value depends on which set you bought. If it's the new design metal/rubber gasket set (part# MS98004T), the new torque spec is in the box. If it's the old plastic/rubber set (part# MS90562), use the factory proceedure which is:
Tighten all the lower intake manifold bolts in sequence to 7 N·m (62 lb in) on the first pass.
Tighten the longer center lower intake manifold bolts in sequence to 13 N·m (115 lb in) on the final pass.
Tighten the shorter outer lower intake manifold bolts in sequence to 25 N·m (18 lb ft) on the final pass.
For reference, tighten the water outlet bolts to 25 N·m (18 lb ft).
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Old 11-08-2006, 03:35 PM   #3
jamesmetairie
hi rich i called felpro earlier and the tech there said to use the same torque specs as the original gasket.i didn,t open the box yet.
Old 11-08-2006, 03:40 PM   #4
jamesmetairie
hi rich i just called felpro at 1-800-325-8886. they say that they don,t give torque specs. they say i must get a repair manual for that. i,m worried about putting this gasket on the car. i have enogh problems without creating more. do you think i should go to the chevy dealer and buy what ever they have if they will give torque specs?
Old 11-08-2006, 03:48 PM   #5
jamesmetairie
finally. i spoke to the felpro manager named jim. he says the torque specs for the metal gasket are exactly the same as the original manufacture. he says they,re not in the box.what a trip here in katrinaland. this is our evacuation car. that,s why i gotta get it right.
Bookmarks
Google
Web AF
