Re: just got a mk3 n/a for 2ook miles
How long it will last all depends on the situation, how the engine was treated it's whole life and how/when all maintenance was done. As an example mine lasted well over 200K miles before I swapped it out, it was still running perfectly when I removed it, regular maintenance and all Toyota replacement parts. More than a few owners have hit 250K+ with the 7MGE, but more realistically your 7M is probably around the end of it's life. Now is the time she needs to figure out what engine she wants to swap before you spend more money on this one, either drop in another GE or do the GTE swap, or something entirely different like a 1JZ.
Don't rig anything up in the car, fix it right the first time and never worry about it for another 15+ years. I can't tell you what's broken with the cable release but you should be able to tell if it's the handle, the cable, or the latch mechanism. Just remove the screws and pop off the center trim plastic in the back of the hatch, that will narrow it down. The car is at an age where certain parts become basic maintenance to replace, like levers and seals. A quick and easy solution is to find another MKIII in a junk yard or online places like ebay and supraforums and get the parts needed.
A manual swap won't cost much for a W58 non turbo transmission, but the turbo R154 will cost more. You could spend $150-400 depending where you get your parts. Labor of coarse is extra, if you pay a shop to do this work it will cost a small fortune.
