04 Impala Speedometer gone haywire.
mark ix
11-06-2006, 08:37 PM
Hi guys, I am having a real time with this one:banghead: . I have a 04 Impala LS with 43k miles on it and all of a sudden the speedometer started reading about 50 mph faster that I was moving. At stop signs it still reads about 60 mph and sometimes when I'm driving along it goes all the way to 120mph and beyond:screwy: . Also there is a strong odor of melting plastic when we park the car and shut it off. The rest of the cluster works fine.
I have located the speedo sensor on the tranny and the wires look to be ok and are connected. I can't seem to find any melted wires or anything. The CEL has not come on at all. The tranny shifts fine and odometer is working fine. Are there any fuses that I can check (it's never that easy!!!!) Any ideas?:frown:
Thanx, Mark
Blue Bowtie
11-07-2006, 09:54 AM
Welcome Aboard!
The signal to the speedometer comes directly from the PCM, and not the VSS (Vehicle Speed Sensor). I've recently had two of these fail on me on different GM models, so it's fresh in my mind. The PCM speedometer output relies on the VSS for correct input, but that same input is used as a reference to control the transmission shift points. If the transmission is apparently operating normally, and the "Check Engine" warning light is not on, I'd suspect either the signal from the PCM or the speedometer (instrument) itself. A competent shop should be able to monitor the signal with an oscilloscope and determine which it might be.
mark ix
11-08-2006, 12:03 PM
Thanx, for the info Blue. I have a couple of questions: Did you notice any odors, like melting plastic when you had the two failures? I noticed this odor when looking under the hood, only when the speedometer is not working properly. When it functions fine there is no odor. And what does PCM mean?
Thanx, Mark
BNaylor
11-08-2006, 12:47 PM
PCM means Powertrain Control Module. It is located in the air box assembly. Where is exactly is the smell centered in the engine compartment? There is a company called Southern Electronics that will repair GM IPs.
mark ix
11-08-2006, 08:22 PM
When the odor occurs it seems to be more near the driver side of the engine, around the radiator hoses and battery area.
Mark
MsDixiesImpala
11-13-2006, 05:49 PM
I have a 2004 Chevy Impala. I'm having problems with the speedometer. At first I thought that it had something to do with the weather. The car was manufatured in Canada and spent it's first years in Georgia before coming here to Mississippi. Some mornings when I take my children to school, it will say that I'm going 0 miles per hour. Then some mornings it will show something faster.:screwy: I thought by turning the car off it would reset itself, that didn't work. I took it to the dealership that I bought it from and was told that it was the INSTURMENT CLUSTER PANEL. And that there have been several people coming in with this same problem with different years but the same make and model, Chevy Imapala. I have been trying to find a recall on this. Can someone, anyone, help me??? I would think that if there have been several people that have had the same problem, that there would be a recall on this???? PLEASE HELP ME! THANKS.
I HAVEN'T SMELLED ANY ODORS. I NOTICE THAT SOME SAID SOMETHING ABOUT AN ODOR. I HAVEN'T HAD ANY.
MsDixiesImpala
11-13-2006, 05:53 PM
What year model do you have? Mine is a 2004 Chevy Impala. I haven't had an odor smell. Just that the speedometer is being really screwy. No lights coming on, such as the check engine.
blackimpalals
01-07-2007, 08:22 PM
Just picked up an LS with 24K miles. Driving home from the dealer the speedo goes crazy. Guess I'll be finding more about this too. Every other gauge is ok.
From what I understand it's a communication problem between the IPC (instrument panel cluster) and the PCM (powertrain control module). I'm getting it checked soon. My guess is I'll need a new cluster. I'm sure that'll be 2-$300 as usual.
adamace1
01-09-2007, 08:44 PM
When this is happening is it efecting the miles on the car too? Like if you didn't fix it would it say you had way more miles on your car than it does, or is it just a speedo problem?
blackimpalals
01-17-2007, 08:09 PM
In my case it's strictly a speedo issue. Under warranty I'm having the instrument cluster replaced. If a whole bunch of instruments are messed up then the powertrain control module may be suspect, particulary if the transmission is shifting goofy.
seve5020
02-20-2008, 07:41 PM
I am having the same exact problem of the "floating needle" on my speedometer but it is not only my speedometer. My fuel gauge needle and RPM needle does the same thing and sometimes they all go back to normal for a little while but eventually my needles are floating somewhere on my speedometer. I called and got an estimate of spending about $400 to fix this because they have to send it out to get a new one and then they have to program the new one to the mileage of my car. I am not too happy with this. Does anyone have another option for this or has anyone heard of a recall on this malfuction? Please respond.
j cAT
02-20-2008, 08:47 PM
go on line to n.h.t.s.a. enter your model year and other info and see if it is listed if not , there are contact numbers and forms to describe your failure ....this i believe should be recall saftey issue......
TEXAS_IMP_RIDA
02-29-2008, 02:07 PM
HEY GUYS I'M HAVING THE SAME PROBLEM AND SOMEONE HOOKED ME UP WITH THE SOLUTION TO THE PROBLEM... CHECKOUT THIS WEBSITE http://home.comcast.net/~bbengineer/cars/impala/ OR EMAIL PERRY @[bbengineer@comcast.net], HE WILL BE ABLE TO EXPLAIN WHAT THE PROBLEM IS AND GIVE YOU SOME ADVICE. HE SERVICES AND SALES GUAGE CLUSTERS FOR IMPALAS AND MONTE CARLOS... I ORDERED MINE LAST WEEK AND SHOULD BE RECEIVING IT TODAY.... PLEASE CHECK HIM OUT, HE'S ALOT QUICKER AND CHEAPER THAN WHAT WOULD HAPPEN IF YOU WENT TO A SHOP...
Admiral Michael
02-29-2008, 07:58 PM
HEY GUYS I'M HAVING THE SAME PROBLEM AND SOMEONE HOOKED ME UP WITH THE SOLUTION TO THE PROBLEM... CHECKOUT THIS WEBSITE http://home.comcast.net/~bbengineer/cars/impala/ (http://home.comcast.net/%7Ebbengineer/cars/impala/) OR EMAIL PERRY @[bbengineer@comcast.net], HE WILL BE ABLE TO EXPLAIN WHAT THE PROBLEM IS AND GIVE YOU SOME ADVICE. HE SERVICES AND SALES GUAGE CLUSTERS FOR IMPALAS AND MONTE CARLOS... I ORDERED MINE LAST WEEK AND SHOULD BE RECEIVING IT TODAY.... PLEASE CHECK HIM OUT, HE'S ALOT QUICKER AND CHEAPER THAN WHAT WOULD HAPPEN IF YOU WENT TO A SHOP...
I agree, he is awesome. He answered alot of questions about putting a overhead DIC in an Impala (I haven't done it yet tho).
TEXAS_IMP_RIDA
03-01-2008, 08:01 AM
I I Recieved My Cluster Last Night Guys... If I Can I'll Post A Pic Of How It Looks...
Daniel Bowen
03-23-2008, 04:50 PM
did this help I have a 2000 Impala where the speedometer sits @ 20mph this is the second time it has happened I donot remember what we did to fix it the first time thought it was as simple as disconnecting the battery but it has not worked
tcmuffler
03-23-2008, 07:28 PM
i installed a alrm systerm in my impala and after that my car get lot of problem because the gay wosnt a profetional i eliminated the alarm and those problem gone
04ChevImp
09-04-2008, 04:12 PM
I recently purchased a 2004 Chevy Impala used (of course) from a local dealership. About 71K. Got a good deal on it, but I assumed and expected to have a few problems with it since it is used. (I test drove several and found this one to be the best/least problems out of all the ones I looked at).
Basically, the speedometer quits on me after sustained freeway driving (+/- about an hour's worth of driving.) Based on all of the research I've done, including reading this AF thread, I've concluded that it's probably the Instrument cluster. As a matter of fact, this problem seems extremely common based on what I've read.
The trans speed sensor, I've been told, is bad if the odometer stops working, which did not happen. So I'm going to roll the perverbial dice, considering a shop is going to want a heck of a lot more than what it will cost to have the cluster repaired.
I did some research and found a place called Mr Whizard Technical services (www.mrwhizard.com (http://www.mrwhizard.com)). Apparently, they can repair the '04 cluster. (There are other speedo repair shops, maybe some closer in geographic proximity, but this place seemed to be the one that had feedback available elsewhere besides on their own website) -- I called them, and I was quoted at $169 (includes shipping). They offer a 5 year extended warranty on repairs above and beyond 2 years for $50.
I called them yesterday (9/3/08), and they emailed me packing/shipping instructions, and a UPS label. They also have '04 Impala dash removal instructions on their site. And, believe it or not, the cluster wasn't that difficult to remove. I just took my time and followed the instructions. Took me about a half hour.
I expected it to be much worse. Only thing is, it's going to take about 2 weeks to get the thing back from them.
Keep in mind, I am not advertising for them or offering a testimonial. However, so far, they seem legit. I shipped my faulty cluster this morning. I will re-post once it comes back and it's reinstalled -- we'll see how it goes.
Also, as a side note, (and to prove I'm just an average joe and not someone trying to conveniently advertise for one company or the other), I also experienced "non-catastrophic" headlight condensation on the driver's side headlamp assembly. This also seems to be a common issue on the 2004 models -- instead of attempting to re-seal/glue/drilling vent holes, I found a good replacement on www.rockauto.com (http://www.rockauto.com) for around $140. I purchased the OEM Standard model, not the cheaper OEM economy model (not by much, maybe like $10 bucks).
I'm pretty happy with it, and it was easy to replace.
