Need to replace front pass. seatbelt latchartrageous 11-05-2006, 03:37 PM Is there any good way to do this? Where can I find the part and how does it attach? Is this a DIY project? Long stupid story, but after gummy worms melted into the latch in August, it hasn't worked. :banghead: We used Goo-Gone and then WD-40 to dissolve the candy and a paperclip to try to remove it all, but my son tried to force the belt part into the latch and I think he damaged the springs (or whatever) inside. Thanks for any help/suggestions you can offer! Bob D. 11-05-2006, 10:31 PM You can't buy the latch part separately if that's what you were referring to - the belt and the latch are essentially one part. A '95 JGC? If it's just the short part that bolts to the floor it shouldn't be a problem labor wise. Should be easy enough to find at a wrecking yard. bringselpup 11-06-2006, 10:55 PM Can you get your hands on a steam cleaner? artrageous 11-08-2006, 06:54 PM Can you get your hands on a steam cleaner? Dunno.... I think it's cleaned out pretty well by now but I'm pretty sure that its innards are damaged. I've been so busy (and have so few passengers!) that this hasn't been a major issue, but it is something that I need to fix or have fixed. I might check with the local body shop and see what they can come up with since they're hooked in to various parts places (and salvage yards) around the area. Automotive Network, Inc., Copyright ©2012
