87 crx >D16Z6 motor swap HELP???
BSoontirFel
09-11-2002, 01:51 AM
I have a 87 CRX dx (d15a2 is in it now) id like to put a D16Z6 SOCH VTEC in it. but im having trouble finding info on trany compatability, and ECU wiering harnes. i think it takes a P28 ECU. DOES ANYONE KNOW SOMTHING TO HELP ME?????????
vwdriver92
09-18-2002, 01:42 AM
well I got a 1st gen and alot of people say that noting from 2nd gens is swappable which is BS, I swapped 2gen brakes and integra rear brakes from a 86-87 and it was a bolt on upgrade, Right now my d15 is turbo in progress I just gotta finish my EIC install, but once that motor goes I wanna swap in a zc or something similar which my home made turbo kit will bolt up except for the exhaust many,
So if you find any info I wanna see it also
One questio for any one is the 86-87 integra ecu will work with the d15 with injectors and fuel rail, so I tried a 89 with the stock d15 injectors and it wont rev past 3g rpm, is this cause of the injectors and fuel rail or what
mellowboy
09-21-2002, 11:16 AM
Man sohc v-tec can fit in your car but i'm not sure if its a str8 bolt on. I know u can put a b16 in it and hasport makes the kit for it. I'm guessing for the sohc v-tec should be a str8 bolt knowing that they are d-series and just get a 2nd gen si tranny so u don't have to do that cable to hydro conversion. I would buy the p28 ecu also. Hope this helps? I'll try to find a site that should explain better than me!:p
