Re: 85 4Runner intermittant sputter and die
Can you smell gas back near the firewall on the passenger side?
If so, then your fuel rail dampener is bad assuming V6.
You will need around 45lbs to 50lbs driving, Instrumenting this is a dangerous undertaking if you do it wrong it will result in a fire and loss of truck shop and or home. There are banjo fittings available to do this I won't however explain how this is done, just too risky and is NOT cost prohibitive to have the pressure checked, make sure they do a road test while monitoring the pressure. There is also the fuel regulator on the fuel rail.
Good luck
