Help with engine lightjrmontg 10-27-2006, 07:25 PM I am getting a code 121 which says Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem - TPS signal does not correlate to MAP sensor signal. and Accelerator Position Sensor (APPS) - APPS voltage input below the minimum acceptable voltage. Does anyone have any suggestions? dksob81 10-28-2006, 06:52 AM I am getting a code 121 which says Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem - TPS signal does not correlate to MAP sensor signal. and Accelerator Position Sensor (APPS) - APPS voltage input below the minimum acceptable voltage. Does anyone have any suggestions? Bad Throttle Position Sensor..... Automotive Network, Inc., Copyright ©2012
