Door panel
Google
Web AF
Loungerist
10-27-2006, 07:16 PM
I have a 1993 two-door and am trying to remove my passenger door panel so I can replace my shattered windshield. I've removed all the door trim screws, the sail panel screws, the long screw under the armrest, the screw behind the lock latch, the door lock button panel, the piece on the door handle that says "Grand Am", and the screw immediately behind that. But the door panel still won't come off and seems stuck on something. Possibly the door handle itself.
What else do I need to remove to take it off?
xeroinfinity
10-27-2006, 10:15 PM
thier are some door panel clips holding the panel on.
If thiers a pocket on the door, thier could be screws holding it on through the door panel.
Heres a link that migth help you, your 93' is toward the bottom.
Door panel removal (http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0e/5f/2a/0900823d800e5f2a.jsp)
Hope that helps!
gravis2000
10-28-2006, 06:05 AM
Hey this is a link to a newer GA but it may help click on the numbered links below really good pics
http://www.a1electric.com/grandam.htm
xeroinfinity
10-28-2006, 08:29 AM
Ya gravis, the old doors are not like the newr ones.
We hav a link here at the grand am forums with the 99+ disassembly for most of the interior parts.
Loungerist
10-29-2006, 04:44 PM
Is there a way to remove the door handle or does a professional have to do it? Because that's what it feels like is holding it on.
Loungerist
10-29-2006, 05:24 PM
My lock panel.
http://www.geocities.com/terrell5506/LockPanel.c
skibum1111
10-29-2006, 06:01 PM
Ahhh yes, that lovely lock lever. You have to remove the plastic cover on the lever. Unlock the door, carefully insert a small screwdriver under the front of the lever and pry it out. The front comes out, grab it and pull the back off the lever. There is a screw hidden behind that lever. Remove the screw, the plastic panel it holds in turns a bit before it comes out. Have fun putting it back in, you have to rotate it then as well while not loosing the lock lever behind it. Have patience, once you get it off and on without any problems it becomes very easy. Good luck.
xeroinfinity
10-29-2006, 11:03 PM
Sorry about that, I forgot that rod lever on the handle.
IT is a pita!
Google
Web AF
