Originally Posted by jamesmetairie
hi i searched this forum and didn,t see any help about this. i have a car with a used car lot decal on the trunk. how do you guys remove it. thanks.
DON't use a razor blade!! If you are anywhere near a razor blade carefully wrap it in paper and discard it or safely hide it until you're done removing the dealer decal or pinstripping!
Best way to remove a dealer decal or pinstripping is with a common hair dryer. That's right. Sure, you'll have to go through the bother and maybe even a little embarassment to set it up, but I can assure you; IT WORKS, and FAST! The time you spend thinking about what else you could use rather then the hair dryer will be equal to the time it takes to remove all the pinstripping and decal from your car, WITH the hair dryer.Simply, direct the heat just in front of the direction of travel that you'll be pulling the decal/stripping off and gently pull the decal/stripping away from the car body. Try to pull close to the body of the vehicle to prevent decal/stripping from breaking. I stripped the stripping off my Caddy CTS in less then two minutes with the hair dryer on the passenger side. Before I read of the hair dryer I attempted to do it on the driver side without anything and it took almost an hour and I had to buy goo gone to remove the glue left on that side. Believe me on this one...HAIR DRYER IS FAST AND FURIOUS!
