Exhaust Manifold Leakingbmr7c 10-24-2006, 05:10 PM My exhaust manifold is leaking on my 02 LTZ. I won't know until I pull the heat shield off. It is either the gasket or the manifold could be cracked. Are either of these common of Trailblazers? Hoping it is just a gasket. rodeo02 10-24-2006, 08:31 PM I have heard of broken/loose mounting studs and cracked manifolds. Hopfully it's a stud and not the manifold itself! Joel 95_ESi_Person 10-25-2006, 01:30 AM does it sound like an old ford pickup? if it does then I have the same problem... tick tick tick tick while driving? bmr7c 10-27-2006, 05:17 PM I hope it's a stud too. I will dig in this weekend. It is sounding worse than an old Ford pickup and progressivly getting worse. rodeo02 10-28-2006, 10:51 AM If the manifold is cracked, try to source a good used one first. A member on another board just paid a GM service dept ~$1500 for a new exhaust manifold r/r for his out of warranty 2003. His was cracked. Joel maxwedge 10-28-2006, 01:59 PM FYI for all ,the exh manifolds are covered on the emissions warranty for 7/70 or 8/80 depending on Calif. or not. rodeo02 10-28-2006, 04:28 PM Max is that right? I just looked over my 2005 manual, and it's as follows: Per my 2005 model year warranty book: 7/70, California Emission Control System Waranty coverage as it applies to a trailblazer: 1. Camshaft Position Actuator Assembly 2. Fuel Rail Assembly 3. Intake Manifold 4. Throttle body 5. Distributer?? 6. Fuel limiter vent valve? 7. Fuel Tank 8/80, Federal Emissions Control System Warranty coverage as it applies to a TB: 1. ECM 2. PCM 3. Vehicle Control Module (VCM)? 4. TCM 5. Catalytic converter There are other 'cryptic' items listed, but they apply to duramax, flex-fuel, northstar, supercharged, turbocharged or hybrid vehicles. Joel Automotive Network, Inc., Copyright ©2012
