Suburban Headlights
Kartracer
09-08-2002, 09:37 PM
Is it just me or does my 96 Suburban have the weakest set of headlights I have ever seen. I even tried the Painless Wiring switch that allows the low beams to stay on when I switch on the high beams. I know brighter headlight bulbs are available but i cant seem to figure out why I should spent a lot of money to get the brightness I should be getting from regular headlights.
Larry Derouin
11-01-2004, 10:09 AM
Sounds like your headlight switch may be on it's last legs. Turn the lights on, wait a few and feel around the switch. If the area is warm/hot to touch, REPLACE the switch.
Here's a link to a "FORD" page where the switch is used to run 2 relays instead of the headlights and all the others. I did this to my F-150 and the headlight voltage jumped from 10.9 to full battery voltage. I did this 3 years ago and haven't had a problem or replaced a bulb yet.
http://www.ford-trucks.com/article/idx/8/039/article/Whiter_Whites_Brighter_Brights.html
This will definately help.
Larry
FastNBody2002
11-07-2004, 07:11 PM
If you want to buy parts, I'd suggest trying this site: www.genuineoem.com I know they've done well in the past and I hope they can take care of you, too.
Fireplug
11-09-2004, 09:50 AM
Are they aimed correct and what is the wiring switch that puts highs and lows on at the same time?? Where do I find that info
Thanks
