Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 10-22-2006, 05:52 PM   #1
rongrzywacz
rongrzywacz Normal reputation
98 Grand AM break mystery
My daughter has a 98 grand am with 120k miles. When the car sits overnight or for over about 8 hrs or so, when I go to drive it, the breaks are real touchy. If you just touch the pedal they seem to grab real hard/quick. After I drive about 100 yrds it fine. I pulled all the wheels, none of the shoes or pads look bad, no leaks. I checked the vacum hose and it looks ok. Does anyone have any ideas?
Thanks for any help..
rongrzywacz is offline   Reply With Quote
Old 10-22-2006, 06:26 PM   #2
xeroinfinity
out saving the world
xeroinfinity's Avatar
xeroinfinity Normal reputation
Re: 98 Grand AM break mystery
For some reason this happens often, esecially when you back up.
A weak wheel cylinders can cause this to happen.
But mostly Its caused by moisture rusting the rotors/drums a little then they become grabby and can drag or lock up.
If they work good otherwise, I wouldnt worry to much.
Tho it wouldnt hurt to flush out the old brake fluid.
It can be done by bleedig them at each wheel repeatedly till it runs clear.
After time break fluid breaks down and gets excess moisture in the lines. Which water moves with less resistance then the break fluid, ie lock ups/dragin wheel.
hope that helps !
1999 Grand Am SS & Grand Am GT 3.4 OHV
Who'd ever thought the "G" in GM would stand for Government Motors.
xeroinfinity is offline   Reply With Quote
Bookmarks
Google
Web AF
