2002 S-10 Does nothingHighOctaneTinting 10-22-2006, 08:30 AM My 2002 S-10 has been running perfect since it was new, this morning it just wont start, all guages work, lights work, radio works. When you turn the ignition switch... nothing. Doesnt click, churn, or nothing. It cranked perfect last night, no clue of a problem till this morning. It is a 4.3, 5 speed work truck. Any suggestions greatly appreciated. Blue Bowtie 10-22-2006, 09:12 AM Welcome Aboard! Clutch fully depressed? Do the warning lamps all illuminate when you try to operate the starter (Bulb Test Mode)? HighOctaneTinting 10-22-2006, 09:40 AM Thanks, yes the clutch is fully depressed and all the lights come on. BlazerLT 10-22-2006, 10:43 AM Fuel pump. Set the key to the position just before start. If you do't hear the fuel pump prime, you have a blown fuel pump. Make sure you use a Delphi pump, DO NOT GO CHEAP AND GET A CARTER, YOU WILL BE SORRY. HighOctaneTinting 10-22-2006, 10:47 AM Thanks I will try that, I didnt realize the fuel pump would cause it not to turn over at all. Thanks again for all the advice, I will let you know. HighOctaneTinting 10-22-2006, 10:53 AM Is the fuel pump a major repair, as far as labor goes? HighOctaneTinting 10-22-2006, 11:21 AM OK, I turned the switch and I can hear the fuel pump click and engage. What do you think I should do next? muddog321 10-22-2006, 04:06 PM No, the fuel pump has nothing to do with not turning over. See if the small wire is still connected to the starter from the ign switch - wire off no crank. see if the the battery terminals are all clean so have voltage and try to jump it with another vehicle or make such the battery is not almost dead. Then there is the clutch interlock switch that cuts the starter out - could be bad or out of adjustment on pedal up behind. BlazerLT 10-22-2006, 04:23 PM Oh I see, my mistake. When you mean no turn over, you mean the starter won't engage or the engine won't fire up? First, check battery coltage. Second, clean and retighten your battery connections and the connections to the starter. HighOctaneTinting 10-22-2006, 04:31 PM Alright, I have put in a new battery and nothing. I will check starter wires, is the clutch switch located under the clutch pedal?:banghead: Thanks again for all the help guys. HighOctaneTinting 10-22-2006, 10:15 PM I found the problem, the starter wire from the battery was broke, thanks for all the help. A+ to everyone.:grinyes: Automotive Network, Inc., Copyright ©2012
