neon wiring99_monte 10-21-2006, 09:11 PM can anyone tell me how to wire 12" interior neons from under the dash to the battery PlayStation3 10-22-2006, 07:38 PM you run a +power lead to a switch then from the switch to the battery then you run a -chassis ground. the hardest part of it is mouting the switch and the neon. and if you want to run mutiple neons then you need a mutiple pole switch number50 03-10-2008, 07:21 PM Go to streetglow.com... They have a good 4 switch panel that you count mount to the roof or on your dash. Since its a 4 switch you can just put 2 neons on the roof and under dash, or in vents and under dash, whatever you want. robkooL 10-10-2008, 10:44 PM You can tap your fuse box if its closer or the back of the cig lighter. '97ventureowner 10-11-2008, 02:29 AM Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date. From AF's Community Guidelines: POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html Closed. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
