92 chevy lumia radio removalpatrickcuff38 10-21-2006, 03:13 PM how do i get the current stock radio out richtazz 10-22-2006, 08:47 AM you need to remove the dash panel around it. If it's similar to a 91 Grand PRix, there are two bots on either side of the console. The passenger side two can be accessed by opening the golve box, the drivers side are tucked behind the knee bolster under the steering column. Then the radio is secured to the dash by 4 bolts that are exposed when youget the dash cover piece off. tblake 10-25-2006, 12:02 AM are you sure rich?my 90's radia came out by gently prying the wood grain trim in front of it, and then taking out the two 7mm bolts. Then the whole thing slid out. Easiest radio i've ever taken out. uH8THECHEVY 10-26-2006, 11:35 PM are you sure rich?my 90's radia came out by gently prying the wood grain trim in front of it, and then taking out the two 7mm bolts. Then the whole thing slid out. Easiest radio i've ever taken out. That is correct Tblake Automotive Network, Inc., Copyright ©2012
