Shock upgrade 101neil 08-28-2001, 03:12 PM 3. Bilstein h2 shocks- i gather these are great improvements over stock. does anyone have pics on how to install them? will they help with sagging in the rear when you are carrying heavy objects? i have noticed that the rear gets "wollow-y" or squishy when carrying heavy stuff-- will the shocks put more control back in the rear suspension? also, i have heard that the rancho rear shocks require the removal of the rear swaybar. can the bilsteins be put in while keeping the sway bar intact? are there other shock options? thanks Schludwiller 08-28-2001, 04:14 PM Turn your thread display to show threads "since the beginning" and you will see that installing the shocks is already covered. Here's the link: http://www.automotiveforums.com/vbulletin/t3255.html All shocks including the Nissan stock ones get damaged by the sway bar rubbing aginst the shock housing. However, once you upgrade your shocks you need the swaybar less. neil 08-28-2001, 04:42 PM thanks for the link and info Schludwiller! Automotive Network, Inc., Copyright ©2012
