90 DeVille. Wire Cam-Pos sensor in distribJim_S 10-19-2006, 07:29 PM I am working on a 1990 Cadillac DeVille 4.5 liter. Inside the distributor there is a Cam Position Sensor, aka Hall-Effect sensor. I need to know how to wire this sensor. The sensor has three terminals. It seems that you are not supposed to need to know how to wire this sensor. There should be three wires coming out of a harness and going to a connector. That connector should fit on the sensor in only one way; no problem in theory. When I started working on this car, there was no connector, just three wires, each with its own single connector. Now, which wire goes to which terminal on the sensor? The sensor has three terminals. The All-Data circuit diagram shows three wires: Pink = 12V when ignition on Brown/white = signal Black/red = ground I have such wires with these colors. At the parts counter at a Dealer, I saw a harness. The connector had just two wires attached. The rightmost was Black/red, and the middle was Brown/white. The leftmost wire was NOT connected!!! This does not seem right. It is physically impossible for a Hall-effect sensor to work without some input voltage (pink wire). It also contradicts the three-wire arrangement in the circuit diagram. None of the three terminals are connected to case ground, so one cannot call it a two-wire sensor by eliminating the ground wire. (I am call the "right" terminal, the one on MY right as I face the sensor.) Does anyone have knowledge of which wire goes to which terminal? Jim S. DFBonnett 10-20-2006, 08:56 AM From left to right as you look down on the switch from above....... pink, brown/white, black/red Automotive Network, Inc., Copyright ©2012
