Re: Help with '94 taurus wagon
If you can either duplicate the noise or find a time when the squeal lasts long enough you can experiment, you could try spraying just about anything on the belt to see if the squeal goes away momentarily. If so, your belt probably has a glaze on it and needs to be replaced.
If you suspect alternator, then turning on the headlights and the blower to high (loading the electrical system) would likely cause the noise to show up. Of couse a slipping belt would still be a suspect in this case as well.
You'll also want to inspect the belt for wear and make sure the pulleys are aligned too. Is there any associated rumbling noise with the hood open and engine running? If the bearings are bad in the alternator, idler pulley, or self tensioner, they would likely cause a low rumble and possibly a squeal as well. To check these out, you could shut the engine off and remove the belt, then spin the various pulleys by hand to feel for roughness. If you notice roughness, regardless of if it is the source of the squeal, you should replace the rough part and may as well install a new belt at the same time.
In the past, we had issues with Goodyear belts (not so much their Gatorbacks though) and Dayco. Good experiences with Kelly-Springfield and Gates though.
-Rod
