Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-18-2006, 10:04 PM   #1
cshults
cshults Normal reputation
Water problem
I have a 2001 Bravada and I am hearing water sloshing around from the roof area towards the back of the vehicle. I can't figure out where the water is. I have raised the rear hatch, have looked around to see if there is any water buildup or to see if there are any drainage passages that were plugged, I can't find anything. It does have a sunroof so I assume that there must be drainage passages somewhere.
Someone please help, it can't be good for that water to be sitting and sloshing around wherever it is.
Chris S.
2001 Bravada Platinum Ed.
1992 Beretta GTZ
cshults is offline   Reply With Quote
Old 10-19-2006, 04:04 PM   #2
Josh Smith
Josh Smith Normal reputation
Send a message via Yahoo to Josh Smith
Re: Water problem
Could it be your gasoline?
Where do you fill up your rear washer fluid? Most were all in front, but some are in back as well.
Josh <><
1993 Olds Bravada, tow package, power everthing and leather seats. Currently in restoration. - RIP. Your engine and drive train were excellent, but in the end, too much rust.
2000 Blazer, loaded, looks showroom new, bought April 4th, 2009
Josh Smith is offline   Reply With Quote
Old 10-19-2006, 04:16 PM   #3
cshults
Re: Water problem
I dont believe it's gasoline, it sounds like a small amount of water trickling around when I make a turn. I thought maybe the washer fluid as well, but I couldn't find a rear resevoir for the fluid, so I'm guessing that it is all housed in the front.
Chris S.
1992 Beretta GTZ
Old 10-19-2006, 04:40 PM   #4
maxwedge
A990 racer
maxwedge Normal reputation
Re: Water problem
Water could be in the rear 1/4 wells, remove the inner rear 1/4 trims or have someone sit back there and try to pinpoint the area while driving, then post back.
maxwedge is offline   Reply With Quote
Bookmarks
Google
Web AF
