removing door panels
Google
Web AF
gizmo331
09-07-2002, 05:03 PM
I need some help from anyone who can give it. I am replacing some speakers on my 98 s-10. i have managed to rem ove almost the entire door panel but am held up by the manual window crank . How do I remove this :confused: ? If anyone can help please contact me at axemenrevolution@hotmail.com or on my AIM name: gizmo331. Thanks.
P.S.: Also if you can get me a diagram that would be helpful...it is not neccesary though.
Jethro
09-27-2002, 08:51 PM
There is a c shaped clip that holds the handle to the shaft. You can get it loose with a bent hanger wire by hooking it and pulling it away from the shaft.
uke78
12-09-2002, 12:32 AM
hey, i know thats anoting. umm i had the same problem. what you have to do if you have like 10$ i wouls sugest going to any auto parts store or chevy dealer and they have a tool that looks kinda like a fork. you slide the tool between the door and the crank and you will see a c clamp the too will pop that of. you could try a hanger like the other guy said but that will drive you nuts.
uke
custmguru
01-15-2003, 02:55 PM
you can also do it with 2 screw drivers... just mash in the door panel a bit and shine a flashlight and push on both ends with the screwdrivers.
Google
Web AF
