Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 10-18-2006, 08:07 PM   #1
mike_flemming
mike_flemming Normal reputation
ABS light on...?
95 lumina ls 150,000 km..have had this problem before but it went away for a few months but now its back. While driving the abs light will turn on ..it always starts after a little driving and doesent turn onn untill i shut the car off. Have had it in the garage and replaced, the sensor, and the relay. What else could it be? sometimes it doesent turn on at all!
mike_flemming is offline   Reply With Quote
Old 10-19-2006, 06:13 AM   #2
mjtr21
mjtr21 Normal reputation
Re: ABS light on...?
you might have to do what i did. i went to a local repair garage and had them put on this huge code scanner. just ask if they can get codes for ABS. with mine they pinpointed that i needed a new front left wheel bearing.
mjtr21 is offline   Reply With Quote
Old 10-19-2006, 02:21 PM   #3
mike_flemming
yea i did that twice..first it was the relay, it was replaced. The second time it was a sensor...so now its dooing it again..but the abs still works.
Old 10-19-2006, 03:51 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
You need t get the ABS code with a ABS scanner.
When the light is on ABS is not working.
Post back code for more help.
MT
MT
MT-2500 is offline   Reply With Quote
Old 10-21-2006, 01:47 AM   #5
guiness77
guiness77 Normal reputation
hey man I know this sounds strange but try flushing your entire brake fluid system, the fluid could be so old it heats up quicker and causes brake failure and/or false readings on scanners. I say this only because you've changed sensors. let me know if that helps any? good luck!
people wouldn't ride in an airplane that hasn't been properly maintained right? So why do people get behind the wheel of a less than maintained car, and then complain about it when it breaks down. I bet if our cars were 37,000 feet above ground we would have better repair histories
guiness77 is offline   Reply With Quote
Bookmarks
Google
Web AF
