Help with codes, please
jerry_rickard
10-18-2006, 02:31 PM
I just recently have had some trans. issues and got the car's comp. read. Well here goes, DTC P0742 and DTC P1811, I read the post for 1811, heard it was the pcs solenoid. Just wanted to confirm that and any help with the other, which i think is the TCC solenoid, would be great! Also any suggestions on where to take it, or can I do this myself, I ain't scared. Thanks in advance.
richtazz
10-18-2006, 02:43 PM
P0742- Torque Converter Clutch Circuit Stock On
The parts are under the transmission side cover, so replacing them involves dropping the engine and trans out of the cradle to gain clearance to remove the side cover. If you're up for that, the actual parts replacement is simple once you get access to them.
jerry_rickard
10-18-2006, 03:06 PM
Well I've also been told that one can set off the other, should I try one first or knock em both out. Also, car is 99 gtp sorry about that. If I did take it somewhere any idea on cost? Trying to save:2cents:
MT-2500
10-18-2006, 04:50 PM
Better head for a good repair shop.
Code 1811 is transmission taking to long to shift.
I do not see a connection with code 742.
First thing to check is fluid level and condition and transmission filter.
Take note on what is in the bottom of transmission pan.
Good Luck MT
MT-2500
10-18-2006, 05:15 PM
After looking at the repair flow chart for a code P0742 it is possiable it could throw a code P1811 as it disables the shift adaptive mode.
But still sounds like a good repair shop is needed for it.
Here is the repair flow chart on P0742.
http://members.troublecodes.net/crunch/742.pdf
Good Luck and let us know how it goes.
MT
jerry_rickard
10-18-2006, 05:21 PM
Yeah I'll probably have to take it to aamco, I work at a tire shop and do business with them. I'll have them r&r the tcc solenoid first. Thanks so much for the help, this can be pricey info, I love the internet!:grinno:
MT-2500
10-18-2006, 05:27 PM
Test it out first befoe throwing parts at it
Print off the repair flow chart for code P0742 and go over it with the repair shop.
It may help point to your problem.
Let us know how it goes.
Good Luck MT
