Engine Pros need your input
Rolm
10-18-2006, 10:37 AM
If 1 cylinder has a 30PSI reading and all the others have a 150psi.
Question
The cylinder with the 30-psi still have enough compression to fire and keep the engine balanced, at this point the engine is running as rough as if a spark plug wire was disconnected. Any suggestions
GTP Dad
10-18-2006, 12:52 PM
No! A 30 psi cylinder needs to be redone as you have been told in several other threads. 30 psi will not compress gasoline enough to fire the gasoline and you are going to destroy the engine if you keep dumping fuel into the cylinder with the plug unhooked. NO wonder it is running badly!
Rolm
10-18-2006, 12:57 PM
The plug is hooked-up, I used that as an example to simulate the way the engine is running
Rolm
10-18-2006, 05:09 PM
Guys have any of you used "Engine Restore" with any success I do know that I may have a broken piston ring
GTP Dad
10-18-2006, 05:37 PM
I have used Restore. It is a very good product for restoring horsepower through improved compression and stops oil burning but it won't fix a damaged piston ring. Only a teardown can do that.
Brass_GA
10-23-2006, 06:21 PM
I've been using it for a while at every oil change and it does seem to do as the labels say.
It's not a "magic pill" for you car though.
I've been considering having my own cylinders honed and new rings installed anyway.
Rolm
10-23-2006, 06:32 PM
If you have a 1997 3.1L good luck on removing the oil pan. I think it it will be easier to pull the engine out.
