Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Supra > General
General Discuss anything having to do with Toyota Supra here.
Old 10-16-2006, 10:06 PM   #1
Turbodog97
Just a Neon
Turbodog97's Avatar
Turbodog97 Normal reputation
New problem after the 7mgte swap...
Well as ya'll know, my friend and I swapped out his 7m from his '90 Supra, and replaced it with an '88 7mgte. After some custom wiring, and makeshift part...making...we were able to start the car. But here's the new,bad part...it's dumping a god aweful amount of fuel. So much it starts to drip out of the exhaust, and the car runs like junk. I was thinking multiple injectors might be stuck, but he says he read in his hayne(spelling) manual that it says if you can hear them pulsing then they are not junk. Well, that seemed a little bogus to me...What do you think?
P.S. How can we find out, for real, if the(if any) injectors are stuck?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Turbodog97 is offline   Reply With Quote
Old 10-16-2006, 10:39 PM   #2
silversup
silversup Normal reputation
Re: New problem after the 7mgte swap...
which ecu u runnin
silversup is offline   Reply With Quote
Old 10-16-2006, 10:43 PM   #3
Turbodog97
Just a Neon
Turbodog97's Avatar
One from an 88 gte
05 Srt4
97 Mx-5
Old 10-17-2006, 12:08 AM   #4
silversup
Is everything completely stock? Could be the injectors but dont u have the ones from the 90?
Old 10-17-2006, 07:07 PM   #5
Turbodog97
Just a Neon
Turbodog97's Avatar
Everything on the motor is completely stock, down to the airfilter...The 88 motor has the 88 injectors; the ones that came with the motor...We still have the old injectors from the '90 motor we pulled. Are they interchangeable(ie same size)?
05 Srt4
97 Mx-5
Old 10-18-2006, 12:51 AM   #6
silversup
As long as they r turbo injectors, they are interchangeable.
Old 10-18-2006, 11:12 PM   #7
Turbodog97
Just a Neon
Turbodog97's Avatar
They aren't the turbo injectors, we pulled them out of the n/a earlier and tried to mate them to the turbo clips but to no avail. Not sure where to proceed from now...
05 Srt4
97 Mx-5
Old 10-19-2006, 01:26 AM   #8
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
TcmaBoy Normal reputation
The turbo and non-turbo injectors are not swapable. First off they have a different flow rate, and secondly they are different impedance. If you have non-turbo injectors on a turbo motor you are certianly going to have problems. Wow, no wonder you are having problems. You are not only swapping between model years, but you are also trying to run a turbo motor with NA parts. They are not interchangable. This is why a clip makes things easier.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
TcmaBoy is offline   Reply With Quote
Old 10-19-2006, 10:28 AM   #9
silversup
Here is a link to test the turbo injectors with a multimeter:
http://www.cygnusx1.net/Supra/Librar...ion=FI&Page=83
Also, pull the codes from the car. Tell us what you find.
Old 10-19-2006, 11:47 PM   #10
Turbodog97
Just a Neon
Turbodog97's Avatar
We weren't sure, you can't exactly blame all the problems we have had on trying to take injectors from the old motor and use them on the new. I think we figured it out once the clips didn't match. He has a slight knowledge of his Supras(size injectors, etc.) and I have no knowledge of supras, but we both have mechanical experience...so while working on stuff we don't always know if it's the right choice, you live you learn...
05 Srt4
97 Mx-5
Old 10-23-2006, 09:09 PM   #11
Turbodog97
Just a Neon
Turbodog97's Avatar
Update:
The whole fuel system has been replaced...Everything has correct voltage and everything has been to the machine shop and cleaned out and etc...So, the whole fuel system is in pristine condition. But still the problem of the dumping fuel; we are almost wondering if it's the ecu; is it even a possibility to be the ecu? Because honestly, everything other aspect has been checked and/or replaced but still this problem persists so it must be something electrical...Any opinions on this...?
05 Srt4
97 Mx-5
Old 10-23-2006, 09:45 PM   #12
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
So, you are running an 88 ECU? Are all the parts 88, or 89+? 89 was a change up year for the motor, so all the parts need to be from an older turbo motor. The older ECU won't be able to run a newer motor. You are probably going to have to go over every bit of electrical with a multimeter and chase the problem out. At least you didn't do like me and take on the headache of swapping a 1JZ from a 93 Soarer into an 88 NA with wiring diagrams written in Japanese.
Old 10-24-2006, 12:26 AM   #13
silversup
Go to this site:
http://www.supras.com/06/techcenter/...86b974379762be
Make sure all is well
Old 10-24-2006, 11:35 AM   #14
Turbodog97
Just a Neon
Turbodog97's Avatar
Every part is from an 88, well I'm pretty sure...Would things like the igniter or injector resistors matter inbetween years?
05 Srt4
97 Mx-5
Old 10-24-2006, 11:59 AM   #15
silversup
I am completing a similar swap myself. The injector and ignitor should be fine, I believe. The rule is that you need a harness and ecu of the similar year of the body you are using. You can tell by the color of the ecu. Yellow earlier years and gray later years. You will need that gray ecu from 89+. I will be using the older 7mgte from earlier years but matching it with a later year electronics. I am not sure if that is causing your problem though. Pull the codes maybe the car is telling exactly what your problem is. Other ideas could be a non working fuel pressure regulator, faulty afm, fauly O2 sensor, faulty ecu. Codes are your friend.
Bookmarks
Google
Web AF
