1993 grand am water pumpTravis M 10-16-2006, 07:01 PM I'm doing a water pump on a 1993 Grand Am with the 3.3 liter motor and I can't get the pulley for the water pump off I have the four bolts out that connect the pulley to the water pump and I read that you have to have the water pump out to get the pulley off to put on the new one, but the pulley is blocking the bolts to get the water pump out! Also I can't get this cast iron piece out that goes to the motor mount because the pulley is blocking the removel of one bolt! Please help!:banghead: xeroinfinity 10-16-2006, 10:44 PM Welcome to AF Travis ! You can use some WD40 around the center of the pully. Then lightly tap around the pully, it should pop off, they get a little crusty and stick pretty good sometimes. Might pry lightly , carefull not to break anything while prying. Automotive Network, Inc., Copyright ©2012
