98 Voyager 3.3L Radiator Drain valve
ggratecc
10-16-2006, 04:17 PM
I just wanted to do my routine maintenance of draining the
radiator and refilling coolant.
However, when I turn the radiator drain valve 90 degrees CCW,
nothing comes out.
Of course I tried removing the radiator cap.
The only thing I can add is that the last maintenance was a
mechanic who replaced the upper and lower hoses.
Any ideas?
MT-2500
10-16-2006, 04:20 PM
nothing comes out.
Any ideas?
Try pulling out a little on it or blowing a little air back into it.
If all else fails you can pull lower rad hose.
MT
webbee
10-16-2006, 04:58 PM
...If all else fails you can pull lower rad hose.
MT
I would go with that option. Those drains are prone to clog, get brittle from heat, and finally crap out/twist off. In this case I let sleeping dogs lay. Pulling the hose at the radiator side will drain faster/more completely than you will get with the drain anyway.
ggratecc
10-16-2006, 05:02 PM
thanks guys, I think you've convinced me to go with the lower hose
method. I tried pushing a bit of wire up the valve , but no-go;
and I'm afraid of damaging it if I pull on it any more.
vipergg
10-16-2006, 06:56 PM
You have to twist then pull out on it before it will open , it has been said that if you do this sometimes the dseal won't seal right after that and to have a replacement handy . Did it once and it did not leak , but you have to turn it then pull out on it and it should drain.
ggratecc
10-16-2006, 07:01 PM
I did try pulling it out (after turning it CCW)with a pair of pliars, but it never budged.
I felt it would break off, so I stopped.
Are you sure the 98 Voyagers are all like this?
vipergg
10-17-2006, 05:26 PM
yup sure , per factory manual turn draincock counterclockwise to unscrew stem.When the drain is uscrewed to the end of the threads turn back 1/8 of a turn and pull the stem out (it removes) from the tank . May take some pressure to pull this out..
Reinstallation : Push draincock assembly body into the tank until it snaps into place. Turn draincock clockwise to tighten .
Bear
10-17-2006, 07:23 PM
Go with the lower hose. I have talked to numerous Daimler techs and they all say that once you open the drian cock, the rubber "O"O ring fractures and will have to be replaced, I took up this test and yup I tore the "O" ring. Now, I only do the lower hose trick.
