car stalls at stops after battery was reconnectedjason borne 10-16-2006, 01:52 AM i just put in a new starter in my 1991 camaro 3.1 but my problem is now my car stalls like its going to die at stops. its wierd because before i unpluged the battery to install the new starter the car ran great. has anyone ever heard of there car stalling or going bad after unplugging their battery is this common for camaros. thank you ........ Dyno247365 10-16-2006, 02:54 AM i just put in a new starter in my 1991 camaro 3.1 but my problem is now my car stalls like its going to die at stops. its wierd because before i unpluged the battery to install the new starter the car ran great. has anyone ever heard of there car stalling or going bad after unplugging their battery is this common for camaros. thank you ........ Does your power die too? Lights? It's not your starter or your battery but your alternator. God I hate when an alt goes. Especially on a foggy highway at 4am. wrightz28 10-16-2006, 10:40 AM Bad connection? :dunno: Dyno247365 10-16-2006, 04:59 PM Bad connection? :dunno: That too, you may have installed your starter wrong, with loose wires. So whenever working on a car, ALWAYS assume something is your fault, so that you don't have to buy another part BEFORE you redo it. jason borne 10-17-2006, 02:29 AM Does your power die too? Lights? It's not your starter or your battery but your alternator. God I hate when an alt goes. Especially on a foggy highway at 4am. i thought it was my alternator so i took it to kragen auto, they ran a test on it and said that it was still good. ikeyballz 10-18-2006, 03:25 AM if the alternator is cheap, get a new one..low power from the alternator can kill your starter.. wrightz28 10-18-2006, 10:44 AM :disappoin If the car ran fine before the starter was replaced, and does not run properly after the work was done, something got messed up in the process of the task, plain and simple. Retrace your steps and your problem, you will find. jason borne 11-19-2006, 02:11 AM its wierd i changed my motor oil and oil filter, let it run for awhile on my driveway. next day took it out and it ran fine. ikeyballz 11-19-2006, 08:56 AM lol, probably two totally unrelated problems.. maybe your idle was just low. :D jason borne 02-18-2009, 11:59 PM some one came up with this (dumb idea) weird idea, when the engine was made at GM they made it to where it had to relearn the idle process evrytime the battery is disconnected. there is only a small mention of it in some manuals Automotive Network, Inc., Copyright ©2012
