low low coolantmaatlock39 10-15-2006, 09:02 PM i have a 95 arora low engine coolant keep flashing on the information panel i add coolant and it still saying low engine coolant, what is my problem? kiway22 10-15-2006, 09:08 PM Did you check to see if your coolant sensor's wire connector is attached? notorious_ 10-24-2006, 11:00 AM Did that resolve your problem at all? I have the same thing happening with my car, that's actually the reason I started searching for "Olds Aurora Forums" today on Google. Each time I start up the car it gives me the low coolant warning and it's clearly at the fill line.:banghead: aurora199540 10-24-2006, 12:13 PM this happened to my 95' not too long ago.if you did any work on the cooling system you could have air in the system or the float in the reservoir may just be stuck giving you the false "low coolant warning"..also make sure the connector which monitors the level of the coolant is still plugged into the reservoir. notorious_ 10-25-2006, 02:55 PM Hmm, I'll check on that connection, thanks. Automotive Network, Inc., Copyright ©2012
