How do I change the turn-signal bulb on my 1999 Honda CR-V???
oaktrimmer
10-15-2006, 03:29 PM
Yes, this should be a ridiculously simple task but I haven't been able to remove the driver's side headlight assembly on my 1999 Honda CR-V yet to be able to get to the bulb. I removed the obvious bolts and screws but I can't get the bottom of the assembly loose. What am I missing here??? The area appears too crowded to be able to reach through "stuff" to be able to simply pull the bulb out while the headlight assembly is still mounted.
whatsleft
11-11-2006, 12:02 PM
You need to go through the wheel well. Remove at least 3 screws holding the shield in place and pull it open. You can then reach in and change the blinker bulb
