Low RPM THEN STALLSKidlex01 10-13-2006, 11:09 PM 2001 GaSE 81,000 KM 2.4l there are so many things that could be wrong but i dont know where to start... There are no codes coming up and it starts fine after it stalls but only to stall again, but one day its gonna not start after it stalls then what... Does anyone have any ideas... Tranny maybe, alternator, etc... i recently had the fuel filter changed but i dont see how that could have caused this to happen it was changed 2 weeks ago and it was fine... Thanks.. Gir-_- 10-14-2006, 03:01 AM give it some gas or open it up a little bit :dunno: (press the pedal slightly when starting to 1000rpms and let it sit for a sec or 2) change plugs/wires/pcv valve clean throttle body with cleaner, new air filter? GTP Dad 10-14-2006, 08:36 AM When you clean the throttle body be sure to clean the idle air control motor. It may be the cause of all your problems but the information that Gir- - gave you is also valid as far as changing plugs and wires, pcv and air filter. When you clean the throttle body use throttle body cleaner not carb cleaner. Also you may want to have the throttle position sensor checked to make sure it is working correctly. Automotive Network, Inc., Copyright ©2012
