10-13-2006, 04:48 PM
Frozen Air Compressor
I recently changed the starter on My 1999 Chevy Lumina LTZ. During the process I discovered the reason the starter died was the fact that the Air compressor froze up, and resulted in the the starter failing.
I was wondering if anyone knew of a way to bypass the aircompressor. I have done this before on another vehicle, but I just can't seem to get the routing of the belt down so it turns the alternator, Power steering, and water pump.
If anyone has done this please let me know how you did it
Thanks in advance
20
10-14-2006, 04:36 PM
AF -Advisor
Re: Frozen Air Compressor
seems i recall an article on http://60degreev6.com about how this is done. It was a while ago, but may want to ping around on this website. Oh, wait you have a 3.8, damnit. could try those forums anywyas.
2000 Pontiac Grand Prix GTP
(3.5" Pulley, DHP 1.0 PCM, ZZP 2.5" High Flow Downpipe, MMS Ported and Polished Lower Intake Manifold, ZZP Stage 1 Ported Throttle Body, 180° Thermostat, NGK Iridium TR6IX)
Check these videos out guys! (Good Stuff)
Honda Cog Commercial
Peter Griffin Fart Cover-Up
10-14-2006, 05:04 PM
AF - Advisor
Thanks in advance
20
Check your local parts place for a bypass kit.
Or sometimes you can replace the compresser bearing if that is what is frozen up.
MT
MT
10-15-2006, 07:10 AM
Lactose the Intolerant
If you don't care if the A/C works or not, I've bought good salvage yard compressors for $30 (pull it yourself yards) or so, just mount another one up.
10-15-2006, 10:08 PM
Thanks a lot. I am looking for a bypass kit for now. But I just might have the whole thing changed. I really am glad I found this place you guys are a wealth of info for these cars.
20
10-16-2006, 08:28 AM
AF - Advisor
20
You are welcome.
Also here is a good AC link.
http://www.autoacforum.com/
MT
MT
10-16-2006, 04:09 PM
parts monkey slayer
Here is a link to Dorman's website, showing the part you need to eliminate the compressor.
https://www.dormanproducts.com/cgi-b...tegory_list=:0
Would you drive any better with that cell phone up your ...?!
