Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-13-2006, 01:26 AM   #1
bakakuso2
bakakuso2 Normal reputation
help drain coolant from 89 corolla
i dont know how to drain the old coolant from the radiator. i know u can fill it from the top, but i dont know how to drain it out. i think its on the bottom of the car. but i dont know where or how it looks like.
the reason i have to drain it is because all the old coolant turned into rust.
bakakuso2 is offline   Reply With Quote
Old 10-13-2006, 01:02 PM   #2
wrightz28
Backstabbing AF Moderator
wrightz28's Avatar
wrightz28 Normal reputation
Re: help drain coolant from 89 corolla
Did you just buy the car? The coolant may be "rusty" looking because it is from during the time that Dexcool came into play and is not green like standard etholyn-glycol mix.
There is a drain (pastic if if memory serves) at one of the corners on the base of the radiator. I think it's stuffed up there pretty good. If you still can't find it, you could (carefully) remove the lower hose.
wrightz28 is offline   Reply With Quote
Old 10-13-2006, 04:25 PM   #3
GSS123
GSS123 Normal reputation
As already stated there is a petcock that you can open at the radiator base or you can remove the lower hose. There is also a threaded plug on the block you can remove to drain the water with the engine block. This plug is difficult remove if it never been touched in the car's lifetime. If you remove plug coat plug with antiseeze before reassembly. If you get everything well drained and flushed out it will take around 2 gallons of 50-50 mix to refill. You can buy the correct antifreeze from Toyota and a reasonable price. They offer both premixed or concentrated solution.
Let us know how you make out with your project
GSS123 is offline   Reply With Quote
Old 10-14-2006, 07:13 PM   #4
bakakuso2
ok so heres how it went.
my friend came over and help me find it. yeah its stuffed up there. dont really notice it unless u look inside the hole. opened it.. HOLY CRAP!! the rust was thick as hell. flushed it with water, it was stick so it stuck to parts of my car while flushing. but yea. mixed the coolant and everything good to go. thanks guys
Bookmarks
Google
Web AF
