2001 deville radio problemarnyl 10-12-2006, 11:02 PM I recently had the radio go out on my 2001 deville.The clock is on and the radio shows volume on the display when it first starts up but no sound.I have a cd cassett in the glove compartment and it has power going to it it will eject the cartrige.The cd on the radio will let you put a cd in and will also eject it but the radio will not work, as will the cassett player. I have on star and it will not work either. I checked the radio fuses and they were fine . I disconnected the battery and hooked it up again and still no luck.Any ideas anyone.Thanks for any input.:frown: pirnaha 12-13-2006, 09:54 PM I recently had the radio go out on my 2001 deville.The clock is on and the radio shows volume on the display when it first starts up but no sound.I have a cd cassett in the glove compartment and it has power going to it it will eject the cartrige.The cd on the radio will let you put a cd in and will also eject it but the radio will not work, as will the cassett player. I have on star and it will not work either. I checked the radio fuses and they were fine . I disconnected the battery and hooked it up again and still no luck.Any ideas anyone.Thanks for any input.:frown:I am not sure if this will help.I had the same problem when I put in my new amp.The system maybe design to not allow anything put in or taken or it will not work properly.My problem went away when I removed the amp. dancruzdts 10-27-2007, 09:26 PM I have the same problem with my 2000 deville did you solve the problem????? Automotive Network, Inc., Copyright ©2012
