XTerra VS 4Runner (1988)jason_2025 08-28-2001, 02:23 AM Hey guys, just found this forum and thought I'd seek out some advice. I'm looking to upgrade from my trusty old 1988 22re 4Runner to an XTerra and was wondering if anyone else had gone a similar route. I've test driven the X a couple of times and find it generally excellent although I think my 4Runner has more responsive steering. I'll check that more carefully on another test drive soon. Anyway, just looking for comments on this upgrade to see if anyone who had done the same was happy with their X. Cheers. J\ gothamist 08-28-2001, 09:58 AM He has the V6 version though. Complete stock to stock, the 4Runner seems a little better offroad--running the torsion bars into the upper control arms makes a lot of sense. Their rear diff plug is also more cleverly protected (changing my rear diff oil took some work with a die grinder to make the square drive hole, uh, square, again.) The 4Runner is definitely more top-heavy (bad for off-camber) but much more protected underneath stock. Of course, if you lift your Xterra, you can post pics like this. :) http://www.beatdriven.com/xterra/4x4lo_mirror/x_vs_4runner.jpg My driving/wheeling impressions are the following: 4Runner has less body roll, with front swaybar connected or disconnected, than the Xterra does. The X has a good bit more usable power...even with 32" Swampers I can hold 5th on highway hills that the 'Runner needs 4th for. The X actually seems to flex better offroad in the back, but the 4Runner has a lot more frame clearance than a stock X, and is spring-over-axle in the rear, which helps reduce the number of low hanging things underneath. The X has a lighter steering feel, but, to me, feels more 'planted' on the highway. The X is a lot quiter...my X with Swampers is about as loud as the 'Runner w/ AT's. The 'Runner has a better crawl ratio, due to transfer case gearing of 2.72:1, rather than the X's 2.02:1. Xcanuk 08-28-2001, 10:03 AM I switched from a '90 4runner to a '00 Xterra, I don't regret the switch one bit.. some features were missing, ( like the roll down rear window etc ), but I'm very happy with my upgrade, found the steering and 4x4 balance better. Mind you, its hard to compare a 10 year old to a newborn, but the X came out further ahead compared to the newer versions of the 4runner. jason_2025 08-29-2001, 03:35 AM Ok, thanks guys. I don't do as much off roading now as I'd like, it's more that I need the cargo space and the ability to carry people for our film making group. We often need to go off-road to locations too so have a decent 4x4 is important. I also want to move up from my 4Runner while it's worth something too. Cheers. J\ Xcanuk 08-29-2001, 11:48 AM In having the 2, the 4runner had more length with the rear seats up, but it seems the X is wider, and you gain height for putting stuff in. With the seats down, the X swallows more. ( Seems like it does ) You might miss not being able to lower the window for the real long stuff, but the rack on the X is real useful for long loads.. jason_2025 08-29-2001, 02:15 PM Hmm, I'd not thought about not being able to put things out the open window in the back but that's only an issue if I want to carry 2x4's and stuff. As far as putting the seats down, I notice that unlike most vechicles you actually remove the X's rear seats. What does one do with them when you do? Is there room to lay them flat against the back of the driver and passenger seats when you fold the backs down? Cheers. J\ rrdstarr 08-29-2001, 02:22 PM I remove the rear seat cushions and privacy cover and leave them at home then fold the back seats flat before I head out four wheeling! Three less things you have to shuffle around! :) Throw your gear in and go! Xcanuk 08-29-2001, 02:41 PM depending where I'm running, the seat bottoms can fit behind the front seats. It comes off similar to the 4runner when folded. The one advantage to the X in folding the seats and leaving the bottoms at home, it gives you 2 nice storage areas in the footwell. I carry all my tools, gear etc in saddlebags, and they store nicely in the wells, giving me full cargo space. When I did the same thing in the 4runner, the bags became cargo, sometimes I had to pile them into the front seat. I tinted the rear windows darker, so I rarely use the cargo screen. jason_2025 08-29-2001, 09:54 PM So exactly how does this work? For example. We have really odd weather here so there are times when I'm driving that I like to keep the front hubs on my 4Runner locked then I can move in and out of 4WD as road conditions merit. An example of this would be when we get snow near home and for most of my commute to work but the roads can be bare and wet near where I work. Can you engage the hubs on the X then switch back to 2WD and drive on bare wet roads for a time? From what I've read it looks like no but I was just wondering. Cheers. J\ gothamist 08-29-2001, 10:07 PM Engage the front hubs by switching into 4HI (while moving <=25 mph and/or stopped), then switch back into 2HI. Now you can switch between 4HI and 2HI at any speed you wish, as long as you don't backup. If you back up, or reverse direction in some other manner (roll back on a hill in 2HI if driving stick, etc.) your hubs will unlock, and then you can't/don't want to switch to 4HI at higher speeds. You can always switch to manual hubs if you want to, $125 and a few hours install time... I should add, no real problem driving on wet roads (or even dry ones) in 2WD with the hubs locked, you just lose a fair bit of mpg due to the increased drag, and put a nominal amount of wear on the front drivetrain components (about the same as driving in 4HI.) jason_2025 08-30-2001, 12:58 AM Ah, perfect. So it will work much like my 4Runner now. Excellent. I've considered getting manual hubs as well so we'll see how it goes once I get my X. In fact, I'm off to see my dealer now. Oh, wait, I have to sell my 4Runner first... Anyone looking for a low-mileage '88 4Runner in mint condition? ;) Thanks for all the tips guys! Cheers. J\ Xlax 08-30-2001, 01:21 AM First : Welcome to the real world X Canuck ! You will NOT regret buying an X. I looked a several different 4x4 when I made my decision to get the X. I traded in a Jeep TJ (97) which had seen some offroading. The drive in the X feels great on highway and even better offroad. I drove a Landcruiser for about 3000 miles while in Africa and must admit that it would be a very close 2nd if I had the dough to get one are they even made any more?. Gothamist ! all I can say is whoa sweet looking truck 6inch lift kit? Claus Harbones 08-30-2001, 02:29 AM Originally posted by gothamist Of course, if you lift your Xterra, you can post pics like this. :) http://www.beatdriven.com/xterra/4x4lo_mirror/x_vs_4runner.jpg Thats a sweet looking X gothamist, but can't you find some place better to show off that beauty than in a driveway! :p Synchro 08-30-2001, 07:34 AM that was just for comparison to the 4 runner. how's about this? is this better for ya? http://www.maxc.org/images/Drivelikesitsrented2.jpg redvalkrie 08-30-2001, 05:32 PM This X is a little too nice & clean! rrdstarr 08-30-2001, 05:39 PM Can we say Abortion? I thought we could! redvalkrie 08-30-2001, 06:17 PM Yeah the color throws it OFF!:bloated: cliffton 07-12-2009, 11:39 PM The 4 runner 07 i got it more muscles look and cool body structured frame and better extremely good handling than xterra 05 or 06..i tried to drove my friends xterra 05 and the stearing handling is very bad,everytime had this speedbump or hole spot,it moves or pull to the right...... Automotive Network, Inc., Copyright ©2012
