Any idea on the hp of a 96 millenia? 0-60?3 double-0 ZX 08-28-2001, 12:54 AM :confused: josedi 08-28-2001, 07:10 AM There are two engines, One is the base Millenia which is a 2.3L V6 170HP, then there is a 2.5L 210HP supercharged which is for the Millenia S. Torque is the same as horsepower on both engines. 0-60 is about 7-7.6 seconds on the standard Millenia and 6.6 to 7.0 in the Millenia S. I hope that answers your questions.:cool: 3 double-0 ZX 08-28-2001, 03:05 PM thanks :) Redbird99 01-12-2002, 10:30 PM Originally posted by jose@di There are two engines, One is the base Millenia which is a 2.3L V6 170HP, then there is a 2.5L 210HP supercharged which is for the Millenia S. Torque is the same as horsepower on both engines. 0-60 is about 7-7.6 seconds on the standard Millenia and 6.6 to 7.0 in the Millenia S. I hope that answers your questions.:cool: Actually, you got the displacements reversed. The miller cycle type S is the 2.3 and the standard 170 HP is the 2.5. those times look about right, however. BTW ... current and former millenia owner here. nice to meet y'all :D 2002 Altima 3.5 SE (alty replaced 1995 Millenia L) 1997 Millenia L 6'5 290lb in a G20 05-26-2002, 11:40 PM can you swap the tranny on the 2.5 L to 5sp from a 626 ??? CarBuff 07-07-2002, 10:03 AM Here is the data on the Millenia engines. Nothing at all has changed on the S engine. These figures are current: S Engine P or L 210 @ 5300 RPM 170 @ 5800 RPM Torque (lb-ft) 210 @ 3500 RPM 160 @ 4800 RPM The torque is different as is the RPM. The best engines produce higher output at lower RPM's - for passenger cars that is. The engine works less and gets better MPG. if all else is equal (weight, etc) Automotive Network, Inc., Copyright ©2012
