i neep hp
contour_joe
10-10-2006, 09:01 PM
i was wondering if anyone knew where to find some proformance parts for my 96 contour se?
pre98zetec
10-10-2006, 09:06 PM
yea i know of one.. its in the junkyard.. inside a taurus/sable engine bay..
give up?
3.0L upgrade.
check out http://www.contour.org/ceg-vb/ tons of info.
Jason43
10-11-2006, 08:20 AM
The bigger question is how you can find this site looking for performance parts and totally miss contour.org?
Zork77
10-16-2006, 11:51 PM
The best way to get parts for your 96 is just like for my 95. look for SVT parts out of a 97 or go to the 3.0 out of a cougar.
beyondloadedSE
10-17-2006, 04:31 PM
Wow, loads of wrong information here.
SVT parts are not available in 97 Contours since the SVT Contour was only made from 98-00.
The 3.0L duratec did not come in cougars. Cougar/Contour guys swap them from a Taurus, Escape, etc.
And btw, not all 96 and 95 parts are interchangable, meaning you cant swap parts from 98-00 onto a 95. Only the 95 Contour had the most differences from all the other Contours. For example, because the 1995 speedo is cable driven, the SVT gauges will not work. Also, because the 95 has vacuum operated secondaries, the larger SVT lower intake manifold will not work either since its controlled by the IMRC. Of course, then theres the whole other issue that 95's use OBD-I and 96+ uses OBD-II.
