2000 Avalon Check Engine Light..GreaseMonkey 09-04-2002, 09:26 PM Help Please... I have a 2000 Avalon XLS and just yesterday the check engine light came one. I took it to Auto Zone and got a diagnostic test..and they told me that my system is too lean and gave me a code: P0171 What does this mean????? Please help... phnelson 09-19-2002, 09:17 PM Just got the Avalon service manual today. (I am trying to track down why my TRAC OFF light is on. System too lean, means that your gas/air mixture is too light on gas. Possible causes are: Loose air intake hose or duct Incorrect fuel line pressure Obstruction in injector Heated oxygen sensory malfunction MAP or MAF sensor malfunction ECT sensor malfunction GreaseMonkey 09-20-2002, 05:26 PM Thanks for your insight..i'll have a friend of mine take a look at it sometime next week...will update u on that afterwards GreaseMonkey 09-20-2002, 05:28 PM By the way, where did u get your Avalon service manual? I need to get one...Thanx phnelson 09-22-2002, 01:37 AM Most car parts stores will have them. I bought mine at Amazon. I'm fortunate enough to work at a junior college that is next door to the Automotive Dept., and they will interpret my codes and reset them for me, or tell me what needs to be done. Hope this helps jparkinsonmd 10-11-2003, 08:56 PM Thanks for your insight..i'll have a friend of mine take a look at it sometime next week...will update u on that afterwards Can you tell me what the solution (and problem) ended up being. Thanks. JP GreaseMonkey 10-11-2003, 10:41 PM Hey JP, Luckily, a friend of mine knew somebody that works for the toyota service center, he said that it was the MASS AIRFLOW SENSOR. Which upon replacing, did fix the problem. I took it to about 5 different shops before that, and they all guessed that it was the O2 sensors. They were wrong of course. There is only one MASS AIRFLOW SENSOR, located on top of the cover of the air filter. GOOD LUCK JP! ToyotaTech 02-13-2004, 03:30 AM The trac light will come on when the check engine light is on also to make u look at the dash. and yes the code u had is for a mass airflow meter make sure that u change your air fliter every 15k miles to help this not happen again. Dirt gets on the meter and shorts it out frowe 08-18-2004, 11:50 AM Help Please... I have a 2000 Avalon XLS and just yesterday the check engine light came one. I took it to Auto Zone and got a diagnostic test..and they told me that my system is too lean and gave me a code: P0171 What does this mean????? Please help... Mine did too. My Haynes manual says it could be one of 6 things 1) Loose intake hose 2) Incorrect fuel line pressure 3) Obstruction in injector 4) Heated oxygen sensor 5) MAP or MAF sensor malfunction 6) ECT sensor malfunction. Be careful, my 2000 Avalon has a 89465 Airflow Sensor, NOT a 89467 Airflow sensor. My engine must have been made pre or early 2000. Be sure to replace with the correct part! I have not solved my problem yet, the dang Air/fuel sensor is $388 retail $275 discount! I think I will replace the MAF sensor? You made any progress? netads 08-23-2004, 07:13 PM I have a 1998 toyota avalon and when I steer the tires all the way to the right it does not return back to center by itself. I have to steer it back. Does anybody know what might the the mechanical malfunction. aoluser1 09-25-2004, 05:45 PM The check engine light came on last night in my 2000 Toyota Avalon. Many thanks to everyone for contributing so that this morning I tried the following steps: 1. Tighten the fuel cap. The label on my fuel cap indicates that I should tighten the fuel cap until it clicks otherwise the malfunction indicator lamp may come on. 2. Clean the Mass Air Flow (MAF) sensor (and let dry thoroughly) with cleaner for auto electrical parts. 3. Disconnect and reconnect the battery to reset the light. I don't know whether it was the loosen fuel cap or the MAF sensor causing the check engine light to come on. But it was easy for me to do both step 1 and step 2 above. If you know how to locate the EFI fuse, you don't need to disconnect/reconnect the battery like me to reset in step 3. I would like to mention one possible factor. A couple of weeks ago, after I took the Avalon to get an oil change, I noticed a burning smell. It turned out that some motor oil was spilled on the magnifold, creating an oily smoke (some of which might end up on the MAF sesnor). The following link, though not for the Avalon specifically, gave me an idea of how to clean the Mass Air Flow sensor: http://www.4x4wire.com/toyota/maintenance/tacoma_4runner_30k/maintenancep5.html Good luck (:)) and make sure you are familiar with the necessary safety precautions before making your personal attempt. johnsonluke 09-25-2004, 05:58 PM I have a 1998 toyota avalon and when I steer the tires all the way to the right it does not return back to center by itself. I have to steer it back. Does anybody know what might the the mechanical malfunction. Did you change or rotate the tires? Remember always change tires in pairs: i.e. either 2 front or 2 rear or all four at the same time. If you change one tire on the front i.e. put a new tire, then that tire will grip the road more and hence will tend to pull the car towards that direction. The solution is change the other tire too. And if you are putting in a single new tire on your car, then always put it at the rear and after 10,000 km you can rotate it to the front. If the tires are not changed nor new nor rotated, then the alignment may be an issue. take it to a mechanic and for 15 USD per tire/wheel, he will align your car and also the steering. Might take an hour though. mechanicwannabe 10-06-2007, 07:09 PM Can anyone tell me exactly how to find the Mass Air Flow sensor in my 2000 Toyota Avalon? I am hoping to clean it as advised in many posts but not positive where it is. I think we found the electrical connector just past the air filter housing but not quite sure where the MAF sensor is. Help! Automotive Network, Inc., Copyright ©2012
