Cruise control quit workingmcarso 10-02-2006, 12:54 PM Cruise quit, all the rear light works, cant find a fuse location in the owners. Anyopne out there that can help. rodeo02 10-03-2006, 04:29 PM Hmm.. if the brake lights are good, fuses are good, speedo works (VSS good), maybe it's a loose connection somewhere. Dunno where to start without a wiring diagram. :banghead: Joel mcarso 10-04-2006, 07:54 AM Well I couldnt find any referenec to the cruise fuse in the manual or under the hood, so i took it to the dealer and they reprogram the PCM for $35.00, while I was their I got an oil change, (Going out of town, had no other time) get this: Oil change and tire rotation cost me $54.20, I usualy go to Walmart where it runs around $29.00 for both, never again Thanks for the response 16th hippy 10-15-2006, 04:59 PM but you also got a brake inspection from a qualified tech, whereas at walmart they most likely don't even look. if they do, then i need to move where u live cause here they are notorious for screwing up oil changes(forgot to fill with oil and things of the like). Automotive Network, Inc., Copyright ©2012
