1991 Dodge Dynasty Speedometer Intermitently goes Out
Uncle1957
10-02-2006, 11:34 AM
Hi All:
I have 1991 Dodge Dynasty. The Speedometer intermitently quits working. It is off more often that not but will jump to life and stay for a couple hundred miles then cut out again.
Any idea on where to even start with this one.
Thanks
Gord
1thunder
10-02-2006, 08:36 PM
try tapping the top of the dash if that doesn't help check fault codes if cide 15 is there replace the speed sensor on the trans above the right axle housing
Uncle1957
10-03-2006, 04:31 PM
Yes tapping on dash if it is strobing on and off does help it... How do I check the fault code? This is a new car for me. Sat for 2 years on a dealers back lot, after having been B & E'd has taken weeks for many of the electronic components to settle in. Speedometer and Odometer are the last hold outs.
Thanks
Gord
1thunder
10-03-2006, 08:54 PM
if tapping on the dash gets the speedo working then generally the speedo head is faulty to check codes cycle key on and off three times ending in the on position and count the check engine lamp flash dont count the first bulb on as this is a bulb check if lamp flashes 2 times and briefly pauses then flashes 2 more times this would be code 22 at the end of the flash codes there should be 5 flashes then 5 more flashes ending in 55 end of test you are looking for code 15 good luck
Uncle1957
10-09-2006, 10:20 AM
Thanks for the info.
Is it normal for the oil pressure gauge to be be below the low occasionally for stop and go driving? Once on open road it rises well above the low reading.
Thanks
Gord
grabbergreendart
12-09-2006, 08:38 PM
I also have a speedo problem too, but on my 92 b-150 van. when it goes out i have no overdrive. if i stop, turn off engine it sometimes comes back. does any one have a clue
tjv83
01-31-2007, 10:26 AM
It's probably your speed sensor. I had a 89 dodge spirit that had the same problem. They have them here at this site for $30. Good luck.
http://www.1aauto.com/1A/SpeedSensor/Dodge/Dynasty
